repair code decipher, please
Old Jan 10, 2005 | 02:48 PM
kwaskow's Avatar
kwaskow
My Father-in Law's 1996 Ford Ranger (4 cylinder) shows a repair code P1443 on his portable datalogger. Can someone please help me decipher it?
Thank you!!!
Old Jan 10, 2005 | 05:31 PM
Donald Rohret's Avatar
Donald Rohret
My Chilton Manual shows a P1443 code as a "Evaporative Purge Flow Sensor Fault". I would investigate all connections to the Fuel Vapor Canister, and electrical connections to the CANP (Canister Purge) Solenoid. Also check your fuel tank filler cap, fuel vapor hoses and fuel tank filler pipe. Of course check the Solenoid itself.
Old Jan 10, 2005 | 05:59 PM
wresleu's Avatar
wresleu
I just replaced my evap cannister for $30 on my 96 I had the same codes
Old Jan 10, 2005 | 08:18 PM
RangerRuss's Avatar
RangerRuss
This website may be very helpful. http://autorepair.about.com/library/ts/bl-obd-main.htm
Russ
Old Jan 10, 2005 | 08:24 PM
BassGuy's Avatar
BassGuy
Canister purge valve fixed my P1443. Cheap n' easy.
Old Jan 11, 2005 | 09:11 AM
kwaskow's Avatar
kwaskow
Thanks for the great info, and as always I really appreciate the help on these forums!!!
Kurt
Old Jan 11, 2005 | 10:14 AM
Rockledge's Avatar
Rockledge
Some more diagnostic info regarding the P1443 code can be found in this discussion:
Evaporative Emissions Control Valve (EVAP) Thread
