mechanical fuel pump question
Old Jan 10, 2005 | 01:44 PM
ford390gashog's Avatar
ford390gashog
Question mechanical fuel pump question
i have mechanical fuel pump question for you guys at high rpms the truck runs great but at idle it will slowly die and i noticed a lot of air bubbles coming through the clear fuel filter i have at slow rpms but they go away at fast rpms any ideas i am thinking it is the fuel pump.
Old Jan 10, 2005 | 03:18 PM
Ford_Six's Avatar
Ford_Six
It's probably a hole in the line somewhere letting air in, or the pickup is partially plugged causing the gas to be vaporized under vacuum.
Old Jan 10, 2005 | 03:59 PM
ford390gashog
the tank is spotless inside the hoses are almost new but the fuel pump is not so i guess i will replace the fuel pump and see what happens
Old Jan 11, 2005 | 03:48 PM
ford390gashog
ok i replaced it and it still has the air bubbles but runs fine i am not sure what to do but being that it ran great i decided to melt the tires in the driveway so now i have a excuse to buy new tires.
