Spring length to set level?
Old Jan 10, 2005 | 06:02 AM
scotttruck's Avatar
scotttruck
How do we measure the rear and front springs height so the truck sets level (at factory standard) after assembly? One of the front springs had a ½" spacer under it when we took it apart. It is important to us to set level. What about re-arching the rear springs or should we buy new front and rear springs for our ’78 f-150 4X4?
Old Jan 10, 2005 | 10:49 AM
ivanribic's Avatar
ivanribic
There's really no way to check these springs off of the truck to check if they'll sit level . . . you'll have to install them to see. Often times springs will tend to sag after a period time from weight sitting on them (particularly the front springs). So even a spring that looks fine may not hold the truck to the height you're expecting. I'm guessing your front end was sitting lower than the rear?
