tachometer shot? Any fixes?
Old Nov 5, 2002 | 05:12 PM
gruveb's Avatar
gruveb
I've got an 83 Bronco with some issues. Although minor, it is very annoying to not have the tach working.
Sometimes it bounces around like a mindless maniac, sometimes it just flops all of the way over to 6 grand and just stays pegged, and often, it just lay there, uselessly.
I did a search on the topic, but couldn't find anything.
Old Nov 5, 2002 | 07:36 PM
hermangarza's Avatar
hermangarza
Did you check the cable?
Old Nov 6, 2002 | 09:10 AM
gruveb's Avatar
gruveb
Where and how? I haven't gotten into it at all because I'm not even sure what to look for.
I checked the wires at the coil and everything looks normal.
Old Nov 6, 2002 | 12:30 PM
Ford_Six's Avatar
Ford_Six
there is no cable for the tach. Check the electrical connections. If you pull the gauge cluster out, you will see an edge connector on the cicuit board. Try just removing and replacing this, maybe hit it with a little contact cleaner, and try the tach.
Jared
Old Nov 6, 2002 | 06:06 PM
steve83's Avatar
steve83
Mine did the same thing. I finally found a replacement in a junkyard. I tried cleaning the terminals, tracing the wiring, even poking around inside the tach, but it was just fried.
Old Nov 7, 2002 | 11:43 AM
gruveb's Avatar
gruveb
I'll give it a shot. I'll let you know what I find.
Old Nov 7, 2002 | 01:58 PM
Whitey078's Avatar
Whitey078
