1978 - 1996 Big Bronco
heater problem
Old Jan 9, 2005 | 08:20 PM
bigdogfool's Avatar
bigdogfool
heater problem
I turned the heat on and got nothing as well as when I turn on the AC. I'm thinking it is the blower motor. Any thoughts?
Old Jan 9, 2005 | 09:30 PM
greystreak92's Avatar
greystreak92
Check fuses first. If I knew which model year you have, I could tell you which fuse. If the fuse blew, it did for a reason. Motor may be on its way out or the resistor module may have a problem. Old age can weaken a fuse enough to pop it too.
Old Jan 10, 2005 | 11:31 AM
bigdogfool's Avatar
bigdogfool
I have a 96.
