Radio display light not working
I have a '98 Explorer XLT. The radio display light is out. I removed the radio to find that there is no bulb to replace. The dealership I went to said they would have to send it out and would take three weeks.
Once in a while, the display comes back on. I don't want to fork over $150 or so for a light. Anyone have any suggestions as to what the repair would be? I this a common problem?
Thanks in advance.
Thanks in advance.
96 Sport - Radio Display
I too have a problem with intermitent loss of radio display. Most recently, mine will no longer allow me to change radio stations when the display disappears ( this did not happen when the problem first occurred). I can tap of the radio a few times and I get back the display and station control. I had a similar problem on my 93 F-150 and it turned out to be a blown fuse but I suspect that is not the problem here. I have not chased it yet but I suspect the problem has is with a bad component internal to the radio. You might try a junk yard for a complete replacement unit. Like you I am not interested in investing a fortune into the radio on one of these vehicles. If you do determine what the problem is, please post.
There have been a number of threads on this subject on this forum. It is a common problem with Ford radios. I suggest you do a search on the subject. I used an Internet service to fix the problem in a Mercury Villager. www.shareamemory.com/radio I was satisfied with their service.
Mason
Mason
