Charging question
Old Jan 9, 2005 | 02:53 PM
Daplumma's Avatar
Daplumma
Charging question
My alt gauge jumps around when the engine is idling and no thing turned on.I can hear the voltage regulator clicking.If I turn on the lights or fan it smooths out and stops clicking.Any ideas?
Joe
Old Jan 9, 2005 | 04:56 PM
jd_sylvia's Avatar
jd_sylvia
Daplumma
Mine does the same thing. When it didn't jump around my battery went dead and I installed a new voltage regulator. Since than everything has been great. I do believe what you are seeing is ok for that year and style charging system.
If I'm wrong here gentlemen please correct me so I can correct mine.
Jon
Old Jan 9, 2005 | 10:10 PM
Dads 66's Avatar
Dads 66
My 66 was doing the same thing and the voltage regulator eventually failed. I replaced the Voltage regulator and have had no more problems with it.
Old Jan 10, 2005 | 07:19 PM
Putt's Avatar
Putt
You can replace the old point style regulator with an electronic one from a newer truck. That will keep the charging more consistent and should stop the needle bounce.
Old Jan 10, 2005 | 07:30 PM
66f100's Avatar
66f100
mine was doing the same thing and i replaced the regulator with a new one. that fixed it. no trouble since.
