There is a vibration throughout the truck.......
If the fan were bent enough to shake THE WHOLE TRUCK, it'd be so bent that it'd dig into the radiator or the belt(s).
Have the tires checked for balance & blisters, and get underneath & try to shake each of your U-joints. If you can make them rattle IN ANY WAY, they're bad. But they're not too hard to change yourself.
Something else to check is your harmonic balancer, rotors, and make sure none of your break calipers are stuck.
`82 F-250 Custom** 4x4 ** 351W ** 39.5--15x16.5** SS- TSL`s ** 6" Lift ** Granny 4-speed**** If you can`t run with the BIG DOGS , stay on the porch!!!
Simple test:
Rev the motor in the driveway. If it shakes, then it's something wrong with the torque convertor or clutch, or something else about the engine.
If it only does it moving down the road, then it's something to do with the driveline, such as driveshafts, rearends, tires, etc.
wow i thought i would come here and help but franklin2 took my thoughts rightoutta my head for locating the general source
well anyway good luck and hope it is nothing major
i had this same problem with my 86 -150 and it turned out to be my u joints werre ole and lackin grease but i replaced em n e way for cheap.
