A/C- Heater Control Head
Old Nov 12, 2002 | 05:55 PM
OldFords's Avatar
OldFords
My wife has a 1981 F100 step-side w/single gas tank. This means that the control head does have the fuel tank select switch.
The control head for the A/C and heater/defrost has gone bad. The electrical switch for the A/C clutch AND the vacuum selector switch are both shot.
Does any one have one they would like to sell, or can you point me to some place where I can buy new or good used at a reasonable cost? The Ford dealer in this town has a lock on parts and charges an arm and a leg.
I also need both sliding door-lock controls.
Thanks,
OldFords bad attitudes
Old Nov 12, 2002 | 08:24 PM
hermangarza's Avatar
hermangarza
Maybe your local junk yard has one. I have theory that maybe mustangs switches can be used for it. A theory
Old Nov 12, 2002 | 08:36 PM
OldFords's Avatar
OldFords
[updated:LAST EDITED ON 12-Nov-02 AT 09:38 PM (EST)]I tried all the junk yards around here, with no luck.
If it were just the vacuum switch that was bad (it is removable from the control head), I could probably find one off of some other Ford model that would work. But, since the electrical switch for the A/C compressor is bad and can't be removed, I need the whole control unit.
Old Nov 12, 2002 | 09:15 PM
OldFords's Avatar
OldFords
