Sponsored by: Real Truck
Hanger vs. Spring Lift?
Old Jan 8, 2005 | 09:14 PM
quadsand's Avatar
quadsand
2004 F250 CC 4x4
I'm sure there a ton of opinions on this. However, I'm interested to know everyone's thoughts. I'm considering the edge 4.5" hanger kit, but it seems to me that a 4" true spring lift is better. I've been told that I could experience problems with hanger kits due to the altered geometry on the front end, not to mention the hefty price tag of the edge system. If I go with a Rancho, Superlift, or ProComp lift, it's a lot less money and I get whole new springs. Thoughts, Opinions, advise?
Old Jan 8, 2005 | 09:26 PM
LuLuGoin2ADiesel's Avatar
LuLuGoin2ADiesel
I was just doing some research on the Superlift system myself. My scenerio may be slightly different than yours as I will be putting a plow on my truck in the near future so I've ruled out a hanger kit. Superlifts system utilizes many more thinner leafs as opposed to the stocks two leafs. Because Superlift uses more leafs, it eliminates the need for more arch on the springs giving you a much better ride. I really like Donahoe/Edge 4" system because it comes with Deaver springs, but that's just way too expensive for me. The ride of the Superlift might not be as good as the Edge/DR, but for the price I hear the Superlift system really delivers an awesome ride.
Old Jan 8, 2005 | 09:58 PM
DCSpecial's Avatar
DCSpecial
As long as you use a hanger and shackle nothing is effected if you go that route. If it was just a hanger or just a shackle then you do start changing the geometry of things.
I have the 4.5" DR hanger and shackle along with the 4" Deaver springs for a total of 8.5" lift without any problem. Springs are soft and flex very well.
The downside of the stock springs is that they many sag some over time...more so if you off road hard. Which is why they also offer the 4" lift system with the 4" Deaver springs up front.
Out of the three other companies you mentioned I stay away from Rancho ( I had their 4" and am glad to have it off the truck), personally I'd stay away from the Pro Comp as well (a buddy of mine ran the 4" Pro Comp and was glad to have it off his truck), I've heard good reviews from people with the Superlift lifts since superlift came out with their select series springs, main thing I dislike about Superlift is that the springs are made in India.
Just my $.02
Old Jan 8, 2005 | 10:07 PM
DougD's Avatar
DougD
Originally Posted by quadsand
2004 F250 CC 4x4
Superlift spring kit is the only way to fly...
Old Jan 8, 2005 | 10:54 PM
quadsand's Avatar
quadsand
[QUOTE=DCSpecial]
May I ask why you and your buddy were glad to have these lifts off your trucks? I want to add that I'm not a serious 4-wheeler. I'm mainly in it for the look and an occasional mild off-road session. Thanks.
Old Jan 9, 2005 | 01:10 AM
DCSpecial's Avatar
DCSpecial
Fairly stiff ride on both, springs didn't flex well. I believe his may have sagged some since his 35/12.50 X-terrains on 16x10s would rub the inner fender well just turning into driveways or parking lots.
He sold his old lift to a buddy of his cheap, and I traded most of my lift to a buddy of mine real cheap.
Also, no matter which lift you go with I'd recommend shocks that are valved specifically for the SD.
Old Jan 9, 2005 | 11:06 AM
{OF}Smiley's Avatar
{OF}Smiley
I'm curious as to who told you that you'd have problems with a hanger kit, a complete hanger kit would not give you any different altered geometry issues than a complete spring kit.
If you like how your truck currently rides with the stock springs do a hanger kit. If you want either stiffer or softer ride then chose the spring lift from a manufacturer that provides such springs. I agree with getting shocks valved for your truck.
Either leveling method has pretty much the same amount of work, cost is many times similar depending on manufacturer and options, and the issues are similar - ie: you will probably want a longer shock, you want the trackbar bracket or adjustable trackbar, etc.
I have snowplow spring with a 3" hanger kit on mine and it functions great for me, although stiff on the road it works great for dunes at higher speeds without bottoming out.
ghunt
Nov 25, 2009 08:13 AM
deveaum
Sep 24, 2009 08:49 AM
Beene
Feb 22, 2009 01:09 PM
Ken2600
Jul 30, 2008 12:45 AM
89CrewCab
Aug 5, 2003 06:18 PM
