Sponsored by: Innova
wiring cd player
Old Jan 7, 2005 | 11:01 PM
Vinford's Avatar
Vinford
wiring cd player
I have a Panasonic Cd player someone put in my truck.
Everytime you turn the truck off you have to go through 4 diffrent functions to get the radio back where I had it.
The radio doesnt stay where it was when you turn truck off?
Is this just a fact of life or is it wired wrong?
Old Jan 7, 2005 | 11:36 PM
yamaha4400's Avatar
yamaha4400
ooch
definately not the wiring probaly a deck malfunction or just on like a scan setting, mess with the deck settings and if no good to come after that shop for a new one,
Old Jan 8, 2005 | 12:22 AM
Renegadesrun's Avatar
Renegadesrun
Sounds like the 12v (constant) is not where it should be, and thus, not retaining memory. (Most times its yellow, and i run direct to the batt)
Old Jan 8, 2005 | 12:42 AM
RomerB2's Avatar
RomerB2
Sounds like either a faulty HU, and if that's the case take it back. Or like renegadesrun said, your constant isn't hooked up. The memory wire, which is red, may be hooked up to your ignition wire, which would let it work, but you won't retain memory, and it can probably hurt the HU because it may not be getting all the power it needs.
Old Jan 8, 2005 | 12:53 AM
Renegadesrun
I just "red" my post, and realized i only posted half the thought. Yea, the red wire can be jumped in along side the radio fuse with a blade connector. If the red is switachable (ie only comes on when key is on) and the yellow is always hot you should b in business. BTW.....I ALWAYS run my own ground. Never depend on a vehicles stock ground.
A test light will help. When done and all is as it should be, deck should be fine. If not, id say its braindamaged.
Betting its wiring.
Old Jan 8, 2005 | 12:56 AM
RomerB2's Avatar
RomerB2
Running your own ground is a good thing to do too. I need to do that myself, it will give you a cleaner connection, and can also give you more power from the internal amp of the HU.
Old Jan 8, 2005 | 11:52 AM
Vinford's Avatar
Vinford
thanks guys I thought it was something to do with a "hot" wire!
Ill check ity out.
lurch16
Feb 27, 2015 02:21 PM
TXtinct
Aug 17, 2011 12:26 PM
jared66
1997 - 2003 F150
Jan 16, 2010 04:34 PM
waldersha
Jul 9, 2005 01:59 PM
balingwire
1997 - 2003 F150
Jan 16, 2005 07:16 PM
