Remove brake rotors
Old Jan 7, 2005 | 06:07 PM
billj6's Avatar
billj6
Remove brake rotors
1999 Ranger 3.0, 4x2
Need to get rotors off and to the shop for turning. Have calipers removed and old pads out. Can't get rotors off because housing is still in the way. Haven't opened grease cup yet. Is there a nut in there to remove?
Old Jan 7, 2005 | 06:31 PM
Rockledge's Avatar
Rockledge
'99 Ford Ranger Manual says:
On 4x2 vehicles, remove the brake disc and hub (1102) as follows:
1. Remove the hub grease cap (1131).
2. Remove the cotter pin.
3. Remove the nut retainer.
4. Remove the spindle nut.
5. Remove the front wheel outer bearing retainer washer (1195).
6. Remove the outer front wheel bearing (1216).
7. Remove the brake disc and hub.
Old Jan 7, 2005 | 06:49 PM
billj6's Avatar
billj6
Caliper bracket?
Thanks, Rockledge. I assume by your answer that the bracket holding the caliper is not a separate part and it will come off with the hub. I'll print out your steps and go down and resume work.
Old Jan 7, 2005 | 08:33 PM
billj6's Avatar
billj6
brackets
Ooops!
Brackets were separate part. Since I never had rotors off in 63,000 miles, I nearly pulled the truck off the jacks breaking the bolts loose. Now to get the rotors turned tomorrow.
