99 Ranger Overheating Problems.
Old Jan 9, 2005 | 08:29 PM
Big Jim M's Avatar
Big Jim M
Well I gotta agree with that! But you ain't gonna drive her far if the radiator is plumb clogged. Think about the way I framed it. The colder it is and the longer the coolant stays in the radiator the colder the return hose will be.
Of course down here in Txeas the lower hose is always too hot to touch.
Big Jim
Old Jan 11, 2005 | 02:15 PM
paerhardt's Avatar
paerhardt
Big Jim,
Did The Test Having The Truck On A Slant And Watching The Coolant In The Radiator. Will Warming Up The Coolant Was Splashing Out And Had To Refill Alot. When The Thermostat Opened The Bubbles Came Up Out Of The Coolant. Did Not Check The Plugs Yet But Scheduled For A Head Gasket At Local Ford Shop. Today The System Did The Same Thing Blowing Coolant Into Overflow. Dropping Truck Off Tomorrow For Service. Will Let You Know What Happens.
Thanks,
Pat
Old Jan 12, 2005 | 04:53 PM
paerhardt's Avatar
paerhardt
Hello,
Letting All You Ford Helpers Know What The Out Come Of My Overheating Problem Was. Ford Garage Said I Need A Head Gasket Replacement With A Shave From A Machine Shop. Also Need A New Water Pump,thermostat,spark Plugs, Antifreeze And Misc. Items. Total Cost $1,600.00 Ouch!!!!!!! But Thanks For All Of Your Input.
Thanks,
Pat
Old Jan 13, 2005 | 02:33 PM
richind's Avatar
richind
paerhardt, I can empathize with you. Just went throught the head gasket
replacement because of coolant leakage (on a 2000 4.0L). Cost me ~$1300
for both sides. But that also included a new serpentine belt, and new oil
pressure sensor, and plugs. I didn't go to the dealer though, went to a local
mechanic. I think the dealer would know your Ford better, and you gotta pay
a little extra for that.
BTW, what's the mileage on your '99?
Good luck!
Old Jan 13, 2005 | 03:21 PM
paerhardt's Avatar
paerhardt
Richind,
The Mileage On My Ranger Is 92k And Really Have Not Had Any Other Problems.
Thanks,
Pat
Old Dec 13, 2015 | 10:34 PM
devinford's Avatar
devinford
someone help
i keep hearing about these sensors that rust out making the coolant rust first what are these sensors called and would this cause my temp gauge to read hot even if my truck seems normal thanks guys
Old Dec 13, 2015 | 10:55 PM
g_k50's Avatar
g_k50
Devinford, start a new thread for your issue.
There are a few items that rust out in the cooling system. Freeze plugs for one
The more likely issue is the same as the one in this thread, Blown Head Gasket.
Start troubleshooting by creating a new thread, then change the coolant to straight water, have the radiator boiled out at a good radiator shop, put it back together and see how it acts.
A blown head gasket will push combustion gases into the cooling system once the engine has reached operating temperature, this extra pressure and air (gases) cause reading issue on the temperature gauges.
Stewart_H
548
Jul 6, 2025 12:14 PM
awq134
2009 - 2014 F150
Nov 16, 2017 11:04 AM
rxk9394
Mar 14, 2017 02:25 PM
Pushachevy
Jul 27, 2016 09:24 AM
crazy96863
Jan 9, 2016 05:47 AM
