tranfer case ID
Old Jan 7, 2005 | 09:00 AM
nebechanezer's Avatar
nebechanezer
tranfer case ID
how do you ID a tranfer case in a 79 1/2 ton if there are no tags on the case?
Old Jan 7, 2005 | 02:10 PM
460f250's Avatar
460f250
There should be markings on the case to identify it.
Old Jan 7, 2005 | 02:32 PM
dino360's Avatar
dino360
Cool
It is probably a 205. The way to tell a 205 is to look at the rear of the tcase. There should be a small round cover plate with three bolts located on the back of it if it is a 205. If it doesn't have that plate, it is probably a 203 but I am not sure how to positively identify the 203.
Old Jan 7, 2005 | 11:03 PM
plowpusher's Avatar
plowpusher
203 has a big round aluminm cover on the back and is wider if the truck has a manual tranny it will be a 205 if its an automatic it could be either also the shifter is different the 205 has 4 positoins 4l-n 2h-4hi the 203 has 5 positions loloc-lo-n-hi-hiloc
Old Jan 8, 2005 | 05:46 AM
79schaefer's Avatar
79schaefer
The 205 transfer case is cast iron while the 203 and 208 transfer case will be aluminum. The 205 is a gear drive transfer case, and the 203 is a chain drive case.
Steve S.
To many to list.
Old Jan 8, 2005 | 07:08 AM
buzzbait65's Avatar
buzzbait65
try this, the biggest difference i see that is obvious is the shifters, the 205 has a rail with one shift arm, the 203 has two arms like on an old manual tranny lnkage setup
http://www.offroaddesign.com/Transfe...ID%20Guide.htm
www.akfabshop.com/alaskaoffroad/tech_2.htm
Old Jan 8, 2005 | 09:48 AM
oldhalftons's Avatar
oldhalftons
if the shift pattern is "high-loc, 4hi, N, 4low, low-lock" it is a np203
"4low, 2high, N, 4high" is a np205
Old Jan 8, 2005 | 12:30 PM
nebechanezer
cool, thanks guys
