Towing Question
Old Jan 7, 2005 | 08:51 AM
Gparcels's Avatar
Gparcels
Towing Question
This might be kind of a stupid question, but I'm really not sure or the answer. If you have a v8 4.6 explorer with 3:73 gears and you use a weight distribution hitch would this be as good as a setup if you were to have an F150 with a 4.6 with a standard class III hitch to tow 5000lbs of boat. The explorer with the dist. hitch is rated up to 7140lbs and i believe the 150 is rated up to 7200lbs, also the kind of towing is only one time down 50 miles at the beginning of the season and 1 time back at the end. Oppions greatly appreciated. Thanks in advance.
Old Jan 7, 2005 | 10:20 AM
mcope's Avatar
mcope
I've towed with both and you are in good shape with either set up. I would go with the F150 if I had a choice between the two, but for 50 miles one way twice a year, the Explorer with the dist hitch is more than capable. Just take it easy and make sure your trailer brakes are working correctly.
Old Jan 7, 2005 | 10:26 AM
C M Budke's Avatar
C M Budke
I'd say with that short a trip, twice a year, you should be okay. Myself, I would prefer the F-150. But if you already own the Explorer.............Like mcope said, make sure you have good trailer brakes and take your time.
Chris
Old Jan 7, 2005 | 01:35 PM
rebocardo's Avatar
rebocardo
> would this be as good as a setup if you were to have an F150 ....
> and i believe the 150 is rated up to 7200lbs.
The Explorer has a narrower track and shorter WB then a F-150. If I had to tow 7k (2k trailer and 5k boat) there is no way I would do it with an Explorer if I could avoid it. You are talking about 2x the weight of the Explorer itself. For only 50 miles I would most likely just rent a U-Haul DRW van to move the boat and do it safely.
Or buy an old beat up Ford F-250 with a 390 in it for $1500 for the short trip that will easily handle it.
Old Jan 7, 2005 | 01:39 PM
Tom's Avatar
Tom
I doubt you'd have problems with either, but the Explorer is built off of the ranger frame, which is much lighter and isn't built for much heavy hauling. The F150, however, is built for that kind of thing.
A better comparison would probably be an Expedition with the 4.6 vs the F150.
But...for hauling this rig only twice a year, the explorer would probably do just fine.
Old Jan 7, 2005 | 01:46 PM
falcor1's Avatar
falcor1
me personally i would stick with the f150.maybe it's just me being finicky but i'd rather stick with a 5 speed stick shift truck than with a recreational suv.i've towed stuff with my '86 f150 than i would ever consider touching with an suv.maybe because i have a supercharged 390 as opposed to the standard 281.
Old Jan 7, 2005 | 01:50 PM
Tom's Avatar
Tom
Good point, but that isn't relevant for most of the newer F150s. The manual trannies they put in them now are mazda built trannies that aren't really meant for towing, and you wouldn't want to tow anything heavy with one, they just don't stand up as well as the modern automatics.
Old Jan 7, 2005 | 02:08 PM
falcor1's Avatar
falcor1
mazda does not build trannys for transfer to ford.now it's true that ford owns mazda but mazda made stuff stays with mazda.they don't even come near to HAVING anything close to a 1/2 ton pickup.
Old Jan 8, 2005 | 12:51 PM
Steina's Avatar
Steina
CO River Rat
Gparcels -
If that boat trailer has surge brakes, you need to make sure the WD hitch you use is compatible with them. Also, keep the weight WAY down in the Explorer (driver only?).
Steve
