question on fuel pressure and N/A & blower motors
I came here seeking some answers on the importance of Fuel Pressure. a friend of mine told me that I run the risk of blowing up my blower motor if my fuel pressure drops. wouldn't the engine just lose power first?
would would an engine blow up if you lost fuel pressure. the engine I'm talking about is a BB ford with a blower and the electronic holley throttle bodies on the blower.
thanks in advance.
- jeff
thanks in advance.
- jeff
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about these systems; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
We are happy to have you on board!~
Enjoy FTE …..
Running a motor LEAN will destroy it.....YES!
It will be down on power to a point. But even normal driving with it being very lean will melt a piston land and could be catastrophic. Under high boost, it could happen and very quickly.
I run a rich/lean gage on my motor just to keep tabs on it. It's a pretty plain jane motor and the old cast pistons DEFINITELY need watched over. I only run 5-6 lbs of boost at the present time, so it should survive for awhile.
