Whats the difference%3F
Old Nov 22, 2002 | 08:07 PM
80rangerf250's Avatar
80rangerf250
Whats the difference between a 351c and a 351w? I know they were built in different places but besides that what is different? Is one better, more horsepower or something? Thanks for your help in advance!!
Joe
Old Nov 22, 2002 | 09:21 PM
Jimbare's Avatar
Jimbare
all alone in the world
windsor is smallblock, cleveland looks like a 351m-400. windsor and cleveland share motor mounts, flywheel, and tranny bolt pattern.
Old Nov 22, 2002 | 09:54 PM
steve83's Avatar
steve83
They're totally different engines, except they happen to have the same nominal displacement. The C is older & was discontinued sometime around 1980; the W was discontinued in '98.
Old Nov 22, 2002 | 10:14 PM
Mil1ion's Avatar
Mil1ion
Have a look here
[link:www.oemfordparts.com/faq/smallblockv8.htm#351M%20(MOUNTED)%20AND%20400|Ford Small Blocks]
Dennis
F.T.E. Assistant Administrator
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 23, 2002 | 09:59 AM
Jens's Avatar
Jens
Hi,
the 351 C is more powerful as the Windsor but the 351W has the better oil system. This could be important if you are plan to modify the engine.
Jens
Old Nov 23, 2002 | 02:35 PM
Ford_Six's Avatar
Ford_Six
Ok, here it is again- Dennis is probably going to kill me for this, but:
The 351c and 351w are close to the same age. They are very similar, and will swap out with no effort. The 351c was not used in trucks aside from the Ranchero, and was dicontinued in 74. The 400 was the same class engine, but shared only the cam and heads, and was produced from 71-82. The 351m was a de-stroked 400, built for emmissions, from 74-82. The 351m/400 block uses 429/460 bellhousings, but otherwise are pretty much on their own.
Check out Bubba's site for info and a history lesson:
http://home.earthlink.net/~bubbaf250/
Jared
Old Nov 23, 2002 | 03:27 PM
Franklin2's Avatar
Franklin2
