I just installed a OEM over head console in my 99 250. the problem is that the truck did not orginally have a overhead console so the wireing harness at the passanger side floor panel does not have the required wireing. i purchased the wire from ford to go from the over head to the plug, but where do i fing the wires required to make this work?
My driver seat has the lumbar support that you twist well this no longer works, any suggestions on how to get this to work.
Well, hopefully not EVERYONE!! Sorry you haven't gotten a response on this forum yet. Have you tried going to the "forums" page on this website and scroll down to the "Misc." section? There are forums there that specifically speak to "electrical", "aftermarket", "audio/video", etc... that the members there may have the quick answer for you.
chris
when I wanted to hook up a wiring harness (from ford) to a self dimming mirror for my Lincoln I ask my parts guy at ford and he printed the harness I had and where it is suppose to be routed all on a couple pages for free I reckon your dealer can do that too good luck
There was a TSB about the seats. It seems there is a cable inside there to maintain tension on the lumbar supports. Apparently the cables keep breaking. If I'm not mistaken, they no longer use that system.
