Intermittent heater blower
Old Jan 6, 2005 | 01:49 PM
jfrankr's Avatar
jfrankr
My 94 Explorer's heater blower works for while, then goes off, a while later it'll go back on. It may, or may not work when originally turned on, but either way it'll work for a while then not, then work and then not .... and so on. It has to be turned on for this to happen and happens at all speeds.
What's up?
Old May 17, 2005 | 11:00 AM
al_wa's Avatar
al_wa
Same, same. Hope you got it fixed. If so what did you do?
Old May 17, 2005 | 06:27 PM
JerrySimm's Avatar
JerrySimm
Sounds like it could be a bad breaker. It will kick out and then reset. If a new breaker doesn't fix it, then it sounds like the blower motor is pulling too many amps for some reason.
Old May 17, 2005 | 11:56 PM
cmtrz's Avatar
cmtrz
Thumbs up
I also have a 94 and had the same problem. The blower motor would go on and off when it wanted to. Try the blower motor relay.
Old May 18, 2005 | 01:45 PM
al_wa's Avatar
al_wa
Thanks for the suggestions. I didn't hear "computer" anywhere which is good. Breakers, relays and wire I can do. Thanks again.
Al
Old May 23, 2005 | 11:22 AM
al_wa's Avatar
al_wa
Working better now. Bad blower motor. Tap it with the handle of a hammer and it would start to run but seldom would start on it's own. Current draw very erratic. Thanks for the suggestions.
Jhow88
Nov 11, 2015 10:54 AM
jschne52
6.7L Power Stroke Diesel
Nov 19, 2014 04:50 AM
Polkster
Sep 6, 2014 09:39 PM
AK FORD GUY
Apr 19, 2014 12:23 PM
99FordXCab
Apr 27, 2012 05:56 PM
