Sponsored by: Real Truck
gearing question
Old Jan 6, 2005 | 01:44 AM
4mil's Avatar
4mil
gearing question
If you were to take a stock f-250 and lift it to fit 37's I know the speed/odo/etc would not read the correct speed. However when you go and re-gear the diffs to similar rpm's of a stock vehicle, shouldn't the speedometer now read close??
I lifted my f-250 put in 37's, re-geared to 4.33's and am still reading slow by 8 mph's according to my gps.
Should I have gone with the 4.56's
F-250 CC 6.0
Old Jan 6, 2005 | 01:56 AM
War_is_my_Shepherd's Avatar
War_is_my_Shepherd
I went with 38" tires and 4.88 gears. Using radar I found 20 on the speedo is actually 22...30 on the speedo is actually 35...and 55 on the speedo is actually 65.
My plan at this point is to install one of the speed correction "chips". I've been looking at the Jet Performance "Accu-Speed" which is $150.00.
Old Jan 6, 2005 | 06:19 AM
slc10844's Avatar
slc10844
On the newer trucks the computer can be reporgramed to compensate for changes in gearing and tire size.
Old Jan 6, 2005 | 06:47 AM
03SD's Avatar
03SD
It will depend on where the signal for the speedometer comes from. On my old 97 F150, it was out of the manual transmission. So it must have been calibrated to read transmission revolutions with a certain diameter tire, this created the speedo signal. Your tire change + gear change should have somewhat offset error.
If for some reason SDs measured wheel revolutions, a gear change would have no effect.
I'm not sure where signal comes from, just thinking out loud.
Old Jan 6, 2005 | 08:46 AM
DCSpecial's Avatar
DCSpecial
Gears won't effect the speedo reading.
The VSS is mounted on the rear diff and gets the reading off of the tone ring that is mounted on the carrier with the ring gear. So, the only thing that's going to effect how fast the tone ring rotates at a given speed is the tire size.
I have the Superlift Truspeed module on my SD for the speedo.
Old Jan 7, 2005 | 12:30 AM
4mil's Avatar
4mil
thanks for the response. I now understand why the gearing wont change the speedometer reading, but will put your rpms back in order.
