tach dash wiring
Old Jan 5, 2005 | 09:11 PM
CdnFord Eh's Avatar
CdnFord Eh
tach dash wiring
I happened to stumble across a complete tach dash from an 82 Bronco at a local wreckers. Looking at wiring diagram I don't see any difference in the wire harness to a regular dash with gauges. Anyone have experience with this swap that could confirm this. Thanks.
Old Jan 5, 2005 | 09:52 PM
srercrcr's Avatar
srercrcr
Should plug and play.
Search the site....lots written about it.
Old Jan 13, 2005 | 02:32 PM
hugger94's Avatar
hugger94
I used this posting thread as reference below to acquire and install a gauge cluster with a factory tach. The only difference was the gauge cluster came from a automatic and mine was a 4-speed. All it took was removing two small screws to swap my (4-speed blank) with the automatic blank. Everything else was plug it in and start it up to get the tach to work.
Link to tach information
https://www.ford-trucks.com/forums/s...highlight=tach+
hugger 94
Old Jan 13, 2005 | 07:35 PM
CdnFord Eh's Avatar
CdnFord Eh
Thanks for the replies guys. I did the swap this past weekend, and all went pretty well. Unfortunelty, the tach is not working. I went over the two wire connection on the driver side fender, by the ignition module, right to the coil and the ground on the distributor. All seemed to be in good order, making contact. I especially made sure I had ground, since it is a eight. Only thing I can think is either connection on the printed circuit (which I doubt it is) or a bum tach. When it gets warmer I'll take it apart again and direct wire the tach itself on its own to verify.
Old Jan 13, 2005 | 08:23 PM
blueovalwonder's Avatar
blueovalwonder
what i would do if i was u...just leave the stock gauges alone and go to the auto parts and buy an aftermarket tach..saves headaches on swaping clusters....just my 2 cents though!
Old Jan 14, 2005 | 05:41 AM
srercrcr's Avatar
srercrcr
The other side of that coin is........
Keep it stock, there's nothing nicer than a clean, stock vehicle.
My 83 XLT is showroom stock, get lots of nice comments.
Old Jan 14, 2005 | 06:17 AM
Sycostang67's Avatar
Sycostang67
I did that swap years ago in my 83, The wire for a factory tach was there, it just wasn't connected. I now may have to do this swap again with the 85 I just got.
Old Jan 14, 2005 | 07:25 PM
CdnFord Eh's Avatar
CdnFord Eh
I kind of like the look of the stock in the cluster, you don't see alot around.
Old Jan 14, 2005 | 07:52 PM
DT 466Man's Avatar
DT 466Man
so if you have factory full gauges all you need is the actual tach and just plug it in?
Old Jan 17, 2005 | 10:39 PM
hugger94's Avatar
hugger94
Yes, basically if the original wiring is intact! At least it was for me. I just finished pulling the tach cluster again because the fuel gauge with that gauge cluster wasn't working. I replaced the faulty fuel gauge with the good fuel gauge from the original cluster. I now have a working gas guage with both tanks.
Hope this helps!
hugger94
