What rears do I have?
Old Nov 28, 2002 | 08:19 PM
Red Beater's Avatar
Red Beater
The truck is in the sig and it's a 4-speed if that helps. But I was just wondering how can I tell what kind of rears do I have and what gearing do I have out back?
Old Nov 28, 2002 | 10:30 PM
HotWhlz85's Avatar
HotWhlz85
Hey Red,
There are two places to check. One is the driver's door jamb should have a white tag with codes on it. On the bottom of the tag is the word axle with a code under it. Your owner's manual will decode it. If you don't have a manual post the code here and we'll decipher it for you. There should also be a tag on the rear end housing that gives you the axle ratios.
Ron
Old Nov 29, 2002 | 09:21 AM
Red Beater's Avatar
Red Beater
Aright thanks I will have to look at the tag. I don't have the owners manaul so I'll post them on here.
Old Nov 29, 2002 | 04:05 PM
Ford_Six's Avatar
Ford_Six
If it's a semi-float, most likely a D60. Somewhere in the ballpark of 4.10's, too.
Jared
Old Nov 30, 2002 | 09:41 AM
Red Beater's Avatar
Red Beater
How do I know if it's a semi float? I'm asking because I got my truck back from the shop yesterday and they did some work on my rear and the tech said it was a full floater. Which is better, semi or full floater?
Old Nov 30, 2002 | 09:54 AM
steve83's Avatar
steve83
A full-floating rear axle is theoretically stronger & safer because it only receives the torque of the driveline. A semi-floating axle gets that load AND the weight of the truck on each rear wheel. If a full floater breaks, that axle is dead, but you can lock in 4WD and drive home in front-wheel drive. If a semi breaks, the wheel comes off.
FFs are easy to ID by the small ring of bolts on the outermost end of the rear hubs. These bolts connect the axleshaft to the hub, and by removing only them, the axleshaft can be slipped out of the axle housing with the wheel still on the ground.
All live (4WD/AWD/FWD) front axles are FF.
Old Nov 30, 2002 | 11:39 AM
Red Beater's Avatar
Red Beater
I just looked at the tag and under axle it says C3.
Old Nov 30, 2002 | 11:48 AM
84f150's Avatar
84f150
C3 Dana limited Slip 6250 3.54
Old Nov 30, 2002 | 11:04 PM
Red Beater's Avatar
Red Beater
Thanks for the info 84f150. I thought that my truck had 4:10's out back, because it revs pretty high going down the road. Also is that a strong rear? I have heard that the Dana 40's aren't the toughest so is mine any thougher?
Old Dec 1, 2002 | 03:53 AM
Jens's Avatar
Jens
