If you cut carefully you can use the same shock brackets you cut from the bottom of the axle and reweld them to the top. I welded mine to the ears on my stock blocks for the time being. When I build my traction bars I'll move them to the top of the axle.
There's nothing wrong with welding to cast. It won't make for the strongest weld ever but it will hold just fine in an application like this. The bead just holds the bracket in place. FWIW you can get a very good weld to cast using a buzz box and a nickle rod (I think it's nickle anyway) but for this the old wire feed does fine.
Yea, its a nickle rod. But in any case, if I can trust my memory all the ones I've cut into were mild steel anyways. While I was waiting to change over my rear mounts I just tack welded a bolt onto the ear and slid the shock onto that. Ended up running like that for over a year because I'm lazy. Never broke though. Hey Ivan, those mudflaps look they work great with your 44's
I think a lot of people have the misconception that shocks basically "carry" all the weight of the rig. That's what the springs are for. All the shocks do is dampen movement so you don't bounce down the road. There's not a whole lot of stress on them unless you have a huge amount of suspension travel. Then again, my advice would be don't try tack welding mounts to your frame when you're drinking or they will fall off while you're on the road. Don't ask me how I know this.
Bwahaha, I'd forgotten about that already. Good point you mention about the lack of actual stress the shock mount sees. Me running mine tack welded with a bolt to the ear for a year while pounding on it is a testament to that.
Yeah, I turned mine up too. I reused the original ones and it only took about 10 minutes to grind the welds off. Used a flux-core wire feed welder to weld them back on to the axle housing. There in basically the same place only turned up for more clearance.
Since I was too cheap to buy shorter shocks, I relocated the original upper shock mounts, too.
I've pounded the snot out of it several times and it's still holding.
i realize that the shocks dont hold the wheight of the vehical, but i was thinking that if you hit a bump going fast enough that it would break it right off.
If you get time go to www.pirate4x4.com and do some reasearch in the general forum on welding to cast. You'd be amazed at how strong even a booty fab weld to cast is.
i'll have to search for some good info.. the last time I tried to weld cast, all the filler flowed into the cracks like solder..
