One thing after another!
1. Cooling temperature sensor out of range
2. Throttle position out of range
3. Intake air charge temperature sensor or vane air temperature out of range
4. EGR Pressure Feedback Fault
5. A/C compressor clutch switch fault
My brother told me he didn't even think the diagnostic tester could read that many codes. Is this true? The battery is extremely low and was when I did the test. Does this have something to do with this, or are all those things really wrong with it? Is it possible that all I need is a new battery?
I'm really lost and don't know a good mechanic I can trust and am afraid of getting fleeced at Ford. I have had some grounding issues be some problem for awhile, but feel like I got a hold on that.
Any help would be great. Thanks
Enjoy FTE
We are happy to have you on board!~
TPS out of range -> This is probably a real fault, though it could be the low battery, or bad grounds. This should not result in a no-start, though it can impact idle and off-idle response.
Intake air out of range -> The engine isn't warmed up. This is an expected result
EGR Pressure feedback fault -> For your truck this is actually the EVP sensor. There is no pressure feedback for this model year. Could be a real fault or the low battery or bad grounds
A/C compressor clutch switch fault -> You are supposed to shut off the defroster and A/C when you run the test. Assuming you did this, this could be a real fault. This is not the source of your no-start condition and is a low priority.
Your brother is wrong. The computer can and will post this many codes.
The ignition module was an OK guess. The next thing in line is the Hall Effect pickup in the distributor. Make sure your grounds are good and the battery is fully charged.
