Headlight Switch?
Old Jan 5, 2005 | 06:48 PM
92lightning's Avatar
92lightning
Headlight Switch?
Lately My headlights don't come on with the first try. I push and pull the switch several times and they come on. Is this a sign of a bad switch? I have a Bulldog remote starter that I have been using .The problem started about the same time I started using the remote,can the remote be causing the problem? I don't want to put in a switch if it is not bad. Thanks for your advice SAV
Old Jan 5, 2005 | 08:17 PM
chrono4's Avatar
chrono4
to find out if its the switch or a loose wire you could pull the switch (just to make it easier) and use a diagram and test the connections, if one doesnt work, then you found your problem. if they all do work then its more than likely a dirty or loose connection that is arcing sometimes and causing them to work. hope this helps
drew
