front tank ,pump and guage problem
Old Jan 5, 2005 | 12:35 AM
edd-e's Avatar
edd-e
Smile front tank ,pump and guage problem
Hi,
I have a 94 4x4 ,5.8 with front and rear tanks. I suddenly lost the fuel pump
and fuel guage at the same time when I switched from rear to front tank.
Any idea's ,maybe grounding problem or relay problem???
Thanks in advance for anyones help,
Eddy
Old Jan 5, 2005 | 02:47 AM
GermanGuy's Avatar
GermanGuy
Do a search in the Misc. Forum, Subforum "... and Fuel System". You should find a lot of threads dealing with this problem.
With such symtoms many members finally found the selector switch in the dash broken.
Good Luck Dieter
Old Jan 5, 2005 | 06:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by edd-e
Hi,
Eddy
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
We are happy to have you on board!~
Old Jan 5, 2005 | 08:35 PM
srhigh mechs's Avatar
srhigh mechs
i have the same problem in a 89 f150 if u can figure itout let me know im known as srhigh mechs thanx
i was just reading and they said that try to pull the instrument cluster out and check the socket in the back try that
Last edited by srhigh mechs; Jan 5, 2005 at 08:48 PM. Reason: may have found awnser
