PTO for Power Steering
Old Jan 5, 2005 | 06:23 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
I have the 226 flat 6 with the factory 4 speed. I have not seen any sources for the power steering pump brackets. Do you think there is a PTO Hydraulic setup from a truck dump bed that could be used for the power steering using a toyota conversion?
Old Jan 5, 2005 | 06:46 PM
oldjeep's Avatar
oldjeep
Easier to either make a bracket or use an electric PS pump. I doubt that your lightweight 3 speed has a pto port on it, and the pto drive and pump are going to be fairly expensive. Have you got the toyota box yet? I've got 2 freebies, but havn't had time to pick them up yet.
Old Jan 5, 2005 | 07:22 PM
Christopher2
Veteran: Navy
No not yet, I was hoping to not have to fabricate brackets. I would like to go electric I have not found a suitable donor vehicle yet.
Old Jan 5, 2005 | 07:34 PM
oldjeep's Avatar
oldjeep
Subaru XT has an electric PS pump that should work fine
Old Jan 6, 2005 | 12:23 PM
51dueller's Avatar
51dueller
With these old PTO's you can't drive the truck with the PTO on or you will wreck the pump or break the PTO shaft. My truck had an electric hoist it's basically a starter motor attached to a small pump but I think it would burn out under continous use.
Old Jan 6, 2005 | 01:58 PM
Christopher2
Veteran: Navy
I actually have a 4 speed, it does have the opening on the side for the PTO. It is the same transmission that is in the larger truck from what I can tell.
Old Jan 6, 2005 | 04:09 PM
51dueller's Avatar
51dueller
The main thing that is limiting you is the max RPM you can run the PTO at is 1500 rpm. At that the PTO will chatter really bad. Also since the PTO is ran off the tranny gear cluster you would not be able to shift the tranny without grinding horribly. I had a PTO for these trannys but I gave it away.
Old Jan 6, 2005 | 05:38 PM
Christopher2
Veteran: Navy
Dueller
I believe you it was just a thought. I guess I am back to the electric pump mounted out of the way someplace I can get hoses made.
Chuck
Where are those Toyota boxes I wouldn't mind getting one?
Old Jan 6, 2005 | 06:07 PM
AXracer's Avatar
AXracer
PS requires much higher pressures and quicker response than most hydraulic pumps are capable of producing.
Old Jan 6, 2005 | 07:39 PM
oldjeep's Avatar
oldjeep
Originally Posted by Christopher2
Chuck
I have to pick them up in New Brighton one of these days, they are sitting at a friends house.
scott1470
Apr 10, 2010 02:28 PM
notso
Dec 14, 2004 02:28 PM
Evan1
Sep 13, 2002 12:02 PM
