Great, now the dash is rattling...!!??
Hi guys, new Question/Problem for today…. I have a 97 and my dash seems to be rattling/creaking. I tried to re-tighten the bolts on the top of the dash, in an attempt to snug everything up. No results. Has anyone also experienced this problem, and found a solution? It’s not really loud, but it does creak when I go over bumps. It is distinctly the passenger side that is having the problem…. The dash is in great condition and no cracks near the mounting holes. Are there other bolts that need tightining? or is there another solution?….Thanks!!
yeah.....i think the previous owner of my truck pulled the dash to wire it for a CB....now when i cruise, the passenger side of the dash is shakin like a madman. i don't wanna pull it off to try and fix it cause i am afraid i will probably break something and it will end up worse than i started...so, i'll live with people riding saying "dude, your dash is vibrating lik crazy"
Hey Rob, sorry to hear about your dash noise. I know how you feel. My dash started squeaking a few months ago and it drives me crazy. It only does it when I hit bumps in the road. Ive taken the WHOLE dash apart twice to try and find it but had no luck. Ive had some else drive my truck while I tried to pin point it exactly. Now its much to cold out to start removing parts again. Guess ill have to deal with it till the spring..
Steve
Steve
Steve
Steve
Seems I develop a new rattle every month this winter. The roads here are rough and the cold doesn't help. I did figure out three of them, though. Looks like we have the same side mirrors, Robb. Sometimes the buzzing I hear is actually one of the mirrors (and they alternate sides) vibrating a little. If I'm outside the truck I can put my hand on the mirror and it'll stop. That's two of them. The third has to do with something in the passenger side door. If the window is rolled up tight, there is a rattle sometimes. All I have to do is hit the down button just enough to relieve some pressure, and the rattle will stop. But then there are some more that are buried deep in the dash that I'm sure I'll never figure out. So, when I get really annoyed, I crank up the Sirius satellite radio and make the whole truck rattle.
hehe, try crankin up 2 Kicker 10 Subs pushed by 800 watts in a regular cab....that makes EVERYTHING rattle even worse than before...including me and whatever poor soul gets to ride with me....but hey, small price to pay eh? oh yeah, the subs didn't start the dash shakin, i just got them a couple weeks ago, so i can't blame them
My dad has the same truck as you Rob and he had a rattle in the passenger side that ended up being the door panel making noise so I pulled off the panel and put some rubber grommets between the panel and the door where the screws go through the door panel. That seemed to isolate the plastic from rubbing on the metal which made a squeaking noise.
Originally Posted by The Grinch
Not to ask the obvious, but what about the glove box? I have a 95 that the GB loosens occasionally.
-Robb
Robbgt
I have a 96' that had the same problem. Turned out it was the area where the defrost vents meet the dash. When you have a chance, put your fingers down through the slots in the dash & apply pressure to the vent inside & see if that stops the problem. It took months for me to figure mine out. I just squeezed some rubber strips between the vent & the dash & that took care of mine. I hope this helps!
