Sponsored by: Auxito
starting problems
Old Jan 5, 2005 | 03:55 PM
bigswanny's Avatar
bigswanny
Question starting problems
Hi all,
I am having a weird problem with my truck starting it is a 2001 F-150 4.2L V6. This problem started about a month ago. I got in the truck in the morning and it started fine but after filling up gas it would not start. Had it towed down to the dealership for a buddy to have a look at it in the morning and it started right up. It ran for the next month and is now not starting again. When I attempt to turn it over it sounds strong but just won't start. Please help!
Old Jan 5, 2005 | 06:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
We are happy to have you on board!~
Old Jan 6, 2005 | 09:40 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Next time it wont start try holding the throttle down a little bit and see if that makes a difference. If it does then you probably have an IAC (Idle Air Control) problem.
If that doesn't help then try cycling the key from off to run a few times before cranking it. If that helps then you may have a partially plugged fuel filter or a bad fuel pump.
Old Jan 20, 2005 | 12:30 PM
bigswanny's Avatar
bigswanny
I just wanted to thank you for the advise. I tried cycling the key from off to run a few times and it did start for a sec. I am replacing the fuel pump. Thanks again and sorry it took so long to reply to your post.
