A/C problems
Old Jan 5, 2005 | 09:47 AM
matthew_ccu's Avatar
matthew_ccu
A/C problems
I have a 1997 Ford Ranger with the 3.0 V6...It's winter time so my a/c doesnt run as much, but lately here in SC it has been 70 degrees so the other day i turned the a/c on, and the compressor did not engage, and after checking the fuses, it clicks on for a min and the off for a few, not normally on off, but it clicks off long enough for the air to start blowing warm air again, this is with the setting on for the coldest setting. It got to the point where sometimes when i turned it to a/c it wouldnt come on at all, and the other times it just wouldnt work right, could it be that fuses are not getting a good connection or something, and i know about the fuses just inside the door panel, but should i look for others, and is there any other connections i need to check...and one more note, my check engine light came on, for a lil while, but went back off..i havent tired to run the a/c yet today, but i will see if it is still doing it, but i would like to fix the problem, not just wait for it to come back.
thanks
Old Jan 5, 2005 | 06:08 PM
Ultramagdan's Avatar
Ultramagdan
I think it's time for a pressure check of your system. I noticed my compressor is not coming on with the defrost on so I'll have it checked.
If it's low on freon, it will not run long enough to cool.
Old Jan 6, 2005 | 03:01 PM
I am Danll's Avatar
I am Danll
Thumbs up
Deffently sounds like a slow leak that has lead to a low charge. frist get the sytem presures checked both high and low. and then go on frm there.
BVA
Apr 3, 2022 11:04 AM
THEDON117
Oct 2, 2016 02:14 PM
Gamma505
May 18, 2015 06:25 AM
fixit5561
Aug 7, 2010 08:14 AM
jwheatley20
Jun 12, 2010 09:16 AM
