Sponsored by: Real Truck
5.4 or 6.8 ??
Old Jan 4, 2005 | 04:41 PM
coolbeans's Avatar
coolbeans
WYO Chapter Leader
Smile 5.4 or 6.8 ??
Howdy all,
I'm planning to buy an 05' SD CC SB 4X4 F-350 or F250, and I'm kinda hung up on which gas engine to get. I do have a 2004 27' TT Rockwood camper, which would be the heaviest thing I tow right now.Truck would be a daily driver to work,etc. towing most weekends for camping,mountains,desert not far away.
Preferably 4:10 gears,either transmission will do. Is there that much difference in mpg to warrant a 5.4?How does the 5.4 stand up to strong headwind? I live in a very windy state (I set myself up for that one! )
and I would like to be able to hold a steady speed while towing or lite.
Any other observations will be appreciated!!
Old Jan 4, 2005 | 04:48 PM
150ford's Avatar
150ford
Get the V-10. MPG is similar between the 2. Youll have plenty off power to tow your camper regardless off the wind with the V-10. The V-10 is only a $600.00 option so it wont break the bank. When you drive a truck as big as the superduty you want power and the V-10 will provide it. Forget the 5.4 get the V-10 youll be happy.
Old Jan 4, 2005 | 04:57 PM
Hoosierdaddy's Avatar
Hoosierdaddy
Ditto the V-10! I've got the 5.4 with 3.73 gears in a crew cab. It's adequate for daily driving, but has a lot to be desired when towing. Head winds slow it a lot and I would not want to pull a travel trailer with it. My next truck will have the V10. Mileage is about the same. I average 12 mpg empty and about 10 pulling a 4000# trailer. I've talked with V10 owners gettig better mileage doing both. The V10 works less to do the same work, so it burns less fuel to do the same job.
Steve
Old Jan 4, 2005 | 05:01 PM
coolbeans's Avatar
coolbeans
WYO Chapter Leader
Thumbs up
This is excellent info! Thanks guys!
Still listening...
Old Jan 4, 2005 | 05:03 PM
Big Orn's Avatar
Big Orn
I vote for the V10.
Better to have and not need than to need and not have.....
Old Jan 4, 2005 | 05:59 PM
HD1340's Avatar
HD1340
Smile
I drive a 2002 F-250 Superduty 4x4 Reg cab XLT V-10 Six speed.
I use it as a daily driver,to plow snow,and tow as much as 10,000 lbs
and it never skips a beat! Get the V-10!
Old Jan 4, 2005 | 06:04 PM
DUKFVR's Avatar
DUKFVR
THANKS Everyone! I had the same problem & was leaning to the V10. I will be ordering me a F350 CC 4X4 with the V10 & 410 limited slip. This will replace my 2000 F350 with a PSD.
Old Jan 4, 2005 | 06:17 PM
Hoosierdaddy
DUKFVR-
I'm wondering . . . Why not get another PSD??????? Seams no matter what you get, it will be less of a performer than what you are use to?
Old Jan 4, 2005 | 06:48 PM
DUKFVR's Avatar
DUKFVR
Hoosier,
I just don't want a diesel anymore. The truck is great, but I feel the gasser is better in mud or seems to be . Places where I took my 3/4 dodge with a 360 with no problem , just about stick my PSD , because of the weight issue. Tired of the noise , 15 qt oil changes, stuff like that. The diesels are great engines & I'm not flaming them at all. I tow an ATV on a trailer alot & a boat about 3000 lbs so I definitly don't feel the need for the diesels. The V10 is overkill too, but I wouldn't own a 1/2 ton 4X4 anymore. I feel the 3/4 & 1 ton trucks are built heavier thus hold up better under harsher conditions such as bad roads etc.
Old Jan 4, 2005 | 06:54 PM
boxcar1974's Avatar
boxcar1974
VEEEEEEEEEEEEEE 10....I love mine!!!!!!!!!
Old Jan 4, 2005 | 07:18 PM
someday's Avatar
someday
the 5.4 in the 150 seems to be under powered so in a superduty i would get the v10. the truck i am going to get, i can only get the v10 or psd and i am going to get the v10
Old Jan 4, 2005 | 08:03 PM
wvabeer's Avatar
wvabeer
If I could change how I ordered my truck I would not have changed a thing V10,6sp,4:30 gears = perfect combo
Old Jan 4, 2005 | 08:17 PM
f2fitty's Avatar
f2fitty
I have a 2000 sd 5.4, 4.10's/4" lift & 35's and it's not what I expected. May go with 4.56's to help turn the tires. It needs a torque monster motor because these trucks are pretty freakin big and once you start goin big you can't stop!
Old Jan 4, 2005 | 08:39 PM
jlstorm's Avatar
jlstorm
I have a 5.4 F250 and I love it, I dont find it under powered BUT I got it knowning I would not be doing any major towing or hauling, in fact a F150 would have been fine but the rebates were so good on the new F250's at the end of 2003 I figured what the heck and bought it off the lot. I do think that if I did a lot of towing or hauling I would go with a diesel though, and skip right over the V10.
Old Jan 4, 2005 | 08:49 PM
captchas's Avatar
captchas
Guest
i had a lot of help here from the v10 forum gang,5.4 and 6.8 get almost the same mpg and as i tow a boat a lot , my 250 is coming with the v10, 600 clams where can you really go wrong. good luck
