4spd tranny question
Old Jan 4, 2005 | 12:14 PM
pheasbo's Avatar
pheasbo
Okay, did a search and didn't come up with anything tangentical to my problem. I did learn a few things so that is good. Here is the problem: 1989 F-150 with 300 I6 4spd (T-18) 120K miles. The tranny won't go into first gear without putting it into second. Even then, sometimes it still won't go into first so I "creep" it forward in second and then it will engage. I thought it was the clutch, I knew it needed replacing but I drove it until the clutch went. Replaced the clutch. Still does it. Doesn't matter if it is warm\cold. Am I losing a sychros?
Second question: Power steering pump. Do these have a place where they normally leak? I am having a hard time determining the leak place. I have been using the Lucas fluid and that has slowed the leak. It appears that it may be leaking from the hose fittings, but it is hard to tell.
Old Jan 4, 2005 | 02:54 PM
low92flareside's Avatar
low92flareside
Could be your clutch hydraulics. If they are not providing the right pressure the clutch may slip. Inspect clutch master and slave cylinder for leaking. Also, check under dash at pedal assembly, I've seen master cylinders leak through the firewall as well.
Old Jan 4, 2005 | 02:55 PM
low92flareside
My power steering pump was also leaking at the hose fitting. I replaced the whole pump, but you should be able to purchase just the hose and fittings.
granny_rocket
Nov 19, 2013 10:57 AM
VWS
1983 - 2012 Ranger & B-Series
Oct 31, 2011 11:26 AM
chadgt
Mar 11, 2009 09:46 AM
JBronco
1978 - 1996 Big Bronco
Feb 8, 2005 08:25 PM
TexasGuy001
Nov 13, 2003 05:11 AM
