clutch slave cylinder problems
Old Nov 11, 2003 | 05:08 AM
TexasGuy001's Avatar
TexasGuy001
Our 1985 F-250 4 spd deisel is having problems with the clutch. The clutch pedal went to the floor and won't come up on its own. The slave cylinder was leaking. We have replaced the slave cylinder and line from the master cylinder. It still won't function properly. Is there something that we are missing or is the master cylinder need to be replaced as well. Any input is welcome. Thanks
Old Nov 11, 2003 | 04:12 PM
Desperado82's Avatar
Desperado82
It has been my luck or the customers luck that if one is bad the other will not support a new part. Replace both master and slave! NOTE: bench blead the master! I have not had any luck bleading them installed!
Old Nov 12, 2003 | 09:14 AM
83 F350's Avatar
83 F350
I have replaced just the slave before, just for the fact that they want to much dang money for that fony stinkin' set-up. They are definitely a pain in the butt to bleed but that is what it sounds like you need to do. But if money is not an issue buy'm both.
Good Luck!
Old Nov 13, 2003 | 05:11 AM
TexasGuy001
Hey Guys,
Thanks for the input. I guess I will just go ahead and replace the whole assembly. It's better to do that than have to take the units apart again if the other one fails. Thanks again.
Jarred Lawrence
Jan 3, 2017 08:11 AM
Tiggie
1983 - 2012 Ranger & B-Series
Sep 5, 2015 08:11 PM
jkschneider
21
Jan 25, 2013 12:42 AM
dyingtolive
15
Mar 29, 2012 11:56 PM
Nightrain
Nov 28, 2009 09:34 PM
