1978 - 1996 Big Bronco
302 Exhaust setup....
Old Jan 4, 2005 | 10:33 AM
DcSkater602's Avatar
DcSkater602
have a stock 302 in a 91 bronco. Better to get dual exhaust or just stick with a single? Ive heard that dual exhaust for a motor that small that isnt putting out alot of performance anyway does not need duals AT ALL and they are inappropriate.
truth or was he wrong?
so duals or no duals...they wont be true duals. Just a 40 series with two outlets.
thx
Old Jan 4, 2005 | 05:47 PM
JetBlackBronco's Avatar
JetBlackBronco
im not sure how the performance is, but i have that on my 91 and it sure does sound cool. i love pulling up to those posers in their rice rockets and letting them here what a real engine sounds like
Old Jan 4, 2005 | 10:48 PM
greystreak92's Avatar
greystreak92
They are right! A good 3" exhaust with a high-flow cat will run every bit as well as duals and you can actually BUY a complete aftermarket system tailored to the 302 in the Bronco. No custom work necessary, no figuring out where to put the "X" or "H" pipe, or how to run the second pipe around the transfer case, just remove the old and install the new. If you aren't talking true duals then the performance issue is a moot point. You would be running a single system with an extra tailpipe for looks.
