It's an 89 Bronco, 351 motor, C-6 transmission, and my daily driver back to work and such.
Tracked down what originally seemed to be just a fuel pump/relay problem. Replaced those and it was good to go.
Unfortunately, doesn't seem to be the extent of the problem. Bronco will sometimes start-run for a few miles. Go run an errand and come back out and
it just cranks. Wait an hour or so, it'll start and run for a few miles. Got it home today, check the low voltage on the coil, coil wire resistance, primary cicuit voltage, etc..... no luck.
Pulled the codes and got the 18 - open spout circuit.
Time to replace the module in the distributor??
Any help/ideas/places to start looking?
Went out this morning - bronco started right up. It appears the problem might be heat related (it was about 25 degrees here last night). Looks like I'll be pulling the distributor this weekend and replacing the module and the stator along with the cap and rotor (I mean, as long as I've got it all out....).
I'll check the codes after it's all back together and see what's what...
