Sponsored by: Auxito
Window air deflector removal
Old Jan 3, 2005 | 03:26 PM
stein78's Avatar
stein78
I just picked up a 2003 F150 FX4 and it has those window air deflectors on all four windows. I think the fronts look good, but it looks real cheesy over the back windows. What is the best way to remove the ones on the back window without damaging the paint? I am assuming that they use some sort of adhesive tape? Will I need to use a hair dryer to head up the adhesive? Any help is appreciated, I just don't want to damage my pefect paint! Here is a pic:
Old Jan 3, 2005 | 07:59 PM
triton_2002's Avatar
triton_2002
Take some fishing line and wedge it behind the deflector and then slide it back and forth to "saw" it off. After that remove the left over adhesive with automotive adhesive remover, this takes off wax too, so remember to rewax the area. Some people like to use a hair dryer/heat gun but I don't think its neccessary. I have the deflectors too, but I had them painted body color and they blend in nicely.
Old Jan 3, 2005 | 08:30 PM
stein78's Avatar
stein78
Thanks triton, i'll give that a shot. But, I'm gonna wait for the weather to warm up, it's too damn cold outside!
Old Jan 4, 2005 | 09:51 AM
BillyBob69's Avatar
BillyBob69
Another item to use to remove the adhesive is brake cleaner. But as TRITON 2002 mentioned, it will strip the wax off too. The fishing line is a great idea and avoids having to put anything damaging under it like a screwdriver to get it to fall from the truck.
Old Jan 4, 2005 | 11:29 AM
Wizardvette's Avatar
Wizardvette
I don't know if you have the same situation, but in my truck, my CD changer is right under the driver rear window. I installed a complete set of vent shades and may find it to be a god send if I ever leave my back windows open and get a unexpected rain storm.
Old Jan 4, 2005 | 04:10 PM
MOOK929RR's Avatar
MOOK929RR
I used fishing line to get the deflectors off, then heated the adhesive up a bit with ahair dryer, then used Turtle Wax Bug and Tar remover. Spray it on, let it sit for about 3-5 mins, then the adhesive wiped right off. Supposedly it has wax in it too, and leaves a waxed finish after you buff it off.
Old Jan 4, 2005 | 07:10 PM
tsc's Avatar
tsc
I second/third/fourth the fishing line.
But to protect the paint. Don't use brake cleaner. WD-40 or Goo-B-Gone/Goop off, works the best. Follow up with a quality wax (I suggest Meguiar's NXT, but then again, I'm a Meguair's fanatic)
Old Jan 4, 2005 | 08:02 PM
stein78's Avatar
stein78
Thanks again for all the advice. I will give the fishing line a try and then some goo-gone. All you will find in my garage is Meguiar's NXT wax!
Old Jan 4, 2005 | 08:22 PM
tsc's Avatar
tsc
Have you checked out meguiarsonline.com?
Old Jan 4, 2005 | 09:01 PM
stein78's Avatar
stein78
Just checked it out, cool site!
3twinridges
Nov 26, 2016 09:01 PM
Nirrtix
1983 - 2012 Ranger & B-Series
Jun 22, 2016 09:12 PM
NCMillwright
2009 - 2014 F150
May 31, 2016 09:51 AM
ubereal2
2009 - 2014 F150
15
Jun 29, 2015 09:37 PM
grendell
Sep 29, 2001 08:19 PM
