High temp. thermstat?
Old Dec 18, 2002 | 03:06 PM
webster's Avatar
webster
82 4x4 F-150 351-W Noticed that it takes a lot of driving to get up to temp. Would it be wise to install a "high temp" termostat.What range? Thanks
Old Dec 18, 2002 | 05:17 PM
Franklin2's Avatar
Franklin2
Sounds like the thermostat may be stuck open. Buy the original temperature thermostat that the parts book calls for, to help eliminate condensation build-up inside the engine(brown foam stuff under the oil cap).
Old Dec 18, 2002 | 05:25 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Go to your local auto parts store or Ford parts counter. Tell them the year and engine size of your truck. Let them supply you with the correct thermostat. It will probably be 195*. I've found that the Motorcraft thermostat will let my truck warm up a little faster than aftermarket brands. The Motorcraft thermostat has fewer and smaller relief holes drilled around the outside flange.
Old Dec 19, 2002 | 04:48 PM
webster's Avatar
webster
Went to the nearest Ford store... Surprise! They were out of stock. Drove to the next Formoco. They had one; but sold me the wrong gasket. No wonder the after market people do so well. Real weak supply system. Put the new one in after modification of the gasket. Now I have a heater! Truck seems much better. Thanks. Webster
Old Dec 19, 2002 | 09:02 PM
steve83's Avatar
steve83
