Starting problems
Old Dec 18, 2002 | 09:27 PM
mvee72's Avatar
mvee72
Starting problems
[updated:LAST EDITED ON 18-Dec-02 AT 10:33 PM (EST)]NEED HELP !!! can anyone answer this ? I have a 1984 f-150 4x4 that will not start. Cant seem to get spark to the plugs. Have replaced the computer, ignition module, coil, plug wires, dist.cap, EAC relay, pick up coil in distributor, and fixed some bad wires, still will not start. Any help would be greatly appreciated as patience is winding down at an alarming rate, ya theres gas in it ! Thanks , Mike e-mail : mtvee@prairie.lakes.com
Old Dec 18, 2002 | 09:34 PM
Mil1ion's Avatar
Mil1ion
Starting problems
We'll start here.
1)Is there power to the + terminal of the coil when the key is in the ON position?
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 19, 2002 | 09:14 PM
mvee72's Avatar
mvee72
Starting problems
yes there is power to and from the coil, still no spark, replaced the distributor cap and still nothing . Thanks, Mike
Old Dec 19, 2002 | 09:36 PM
steve83's Avatar
steve83
Starting problems
Sounds like you have a rare '84 EFI, right? The Haynes manual give a very thorough and detailed prodedure for diagnosing ignition faults.
Old Dec 20, 2002 | 03:23 PM
mvee72's Avatar
mvee72
Starting problems
the truck has a 300 six cylinder with carb. I have been working with a chilton manual , but not getting the information I need , is a haynes manual more informative ?
Old Dec 21, 2002 | 10:28 AM
steve83's Avatar
steve83
Starting problems
[updated:LAST EDITED ON 21-Dec-02 AT 11:29 AM (EST)]I think so. Just $12 most places.
Old Dec 21, 2002 | 04:02 PM
82F100SWB's Avatar
82F100SWB
Starting problems
If you're working on these trucks without the Ford manuals, you pretty much have to have BOTH the Chiltons and Haynes, even then, there's alot of stuff not covered.
If you hadn't spent so much on new ignition parts, I'd reccomend that you go to a non-feedback carb and a Duraspark-II setup.
With the feedback TFI-IV, you will still get spark even without the computer hooked up, you just won't get any advance...
If you have power to the + side of the coil, it sounds like you aren't getting a signal from the pickup.
I was gonna type in the Ford test procedure, but, it's too long... I'll just scan it...
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Old Dec 21, 2002 | 08:13 PM
mvee72's Avatar
mvee72
Starting problems
could the ignition module have gone bad again ? or been faulty out of the box ? is there anyway to test this stuff to eliminate possible problems ?
Old Dec 21, 2002 | 09:04 PM
steve83's Avatar
steve83
Starting problems
Yes, you can buy brand new bad parts, and yes, there is a test procedure in the HAYNES MANUAL.
Old Dec 22, 2002 | 12:10 AM
82F100SWB's Avatar
82F100SWB
Starting problems
I only managed to get the first 2 pages of the Ford test procedures scanned before my scanner died, but, they're here: http://www.bigblocksix.com/f100swb/tfitest/
Evan
Old Dec 22, 2002 | 11:30 AM
hermangarza's Avatar
hermangarza
Starting problems
autozone.com has a manual for this truck and i had the same problem on friday i just replaced the starter. maybe this can help u a bit?
Old Dec 22, 2002 | 01:03 PM
1984_355w's Avatar
1984_355w
Starting problems
Jose A.
Aerostar
Apr 11, 2014 12:35 PM
PSD2005
1997 - 2003 F150
Apr 10, 2014 09:34 PM
Marco1316
2004 - 2008 F150
Dec 22, 2008 08:11 AM
3/4tonterror
20
Dec 7, 2007 04:13 PM
Lucky Charms
Electrical Systems/Wiring
36
Jan 7, 2007 11:21 AM
