speedometer error
Old Jan 3, 2005 | 12:29 AM
fiddler's Avatar
fiddler
speedometer error
I have a 82 ford f150 and do not know the original rear end ratio, but have installed 3.50 ratio gears in it and now my speedometer is showing way to fast. I believe it has a T18 transmission in it. What combination of speedometer gears do I need to correct this situation? I am running 235/15/70 tires. Any help would be greatly appreciated Thanks.
Old Jan 3, 2005 | 06:41 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable on these systems; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you!~
See you on the boards.
