Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Engine Hoist
Old Jan 3, 2005 | 12:14 AM
ford2go's Avatar
ford2go
Engine Hoist
I'm looking for a good engine hoist for occassional use. I found one at Northern Tool (Northerntool.com) for $199. I looked it over, and its obviously an import -- the brightly painted steel and crude workmanship gives it away. Does anyone have any experience with this hoist? I would probably only use it 3-4 times a year, so I don't need a commercial grade tool. But, it has to be reasonably solid, I'd hate to have it bend the first time I tried it. Any reports on this one, or an alternate would be greatly appreciated.
Thanks !
ford2go
Old Jan 3, 2005 | 09:34 AM
ronclark's Avatar
ronclark
Don't know about the particular hoist tou are talking about, but if you are only going to use a few times a year, you should get one of the fold up types that can be folded up and rolled to a corner when not in use. I had one of the non fold up types for years and it was always in the way. Brought a new fold up hoist and now can push it into the corner out of the way.
Old Jan 3, 2005 | 01:26 PM
Longneck's Avatar
Longneck
If you have a Pep Boys near by you can pick one up for $100 ($119 - $20 mail in rebate). I think the offer goes until the end of the month (1/31).
Longneck
Old Jan 3, 2005 | 02:02 PM
460f250's Avatar
460f250
The one I use is home made, unfortunately you can't make them for what you can buy them.
I agree though, either get a fold away one or at least one you can break down to store.
Old Jan 4, 2005 | 03:10 PM
gatesj's Avatar
gatesj
With big safety items the rule of thumb usually is to buy better stuff to be safe. With the engine cranes though I just can't see it. Those things are overbuilt even though they are cheap. I got a cheap one and have used it several times with no problems. Check out Harbor Freight, I saw one for $169 or so last night in my local HF store.
Old Jan 4, 2005 | 06:47 PM
maverick man's Avatar
maverick man
the cheap engine cranes are OK, just stay away from the cheap engine stands. i had a 1000LB Taiwan special and even with a small block on it the crank pulley was heading south. stay away from these or the engine will be on the floor.
Old Jan 5, 2005 | 06:59 AM
fellro86's Avatar
fellro86
The major thing to watch on thses is the hydraulic cylinder. I bought an Allied a few years back. The frame was great, it's the darn cylinder that failed. I had to buy another at the tune of $80 to get it to work out. I had taken the cylinder back under warranty to just have that one fail as well. It wouldn't go up with a load, kinda the point of having the thing. Make sure to check out the warranty, and keep your receipts
Old Jan 5, 2005 | 07:54 AM
sdetweil's Avatar
sdetweil
I have the Harbor Freight 2 ton folding hoist.. works great. Had my 460 and C6 tranny up about 5 ft, at the 1/2 ton setting. (460+C6 is approx 850 lbs).
The only thing I don't like is the leg spread, you can't get an engine stand in there to set the engine on easily. The Pep Boys one I looked at had the square stance legs instead of the HF V shape. Both are folding so its not a storage issue.
Make sure to get one with swivel casters on all corners.. amazing how much you need to move it around when the engine is lifted..
I wish my engine stand (2 ton HF) was the folding leg version.. gotta find some casters to make that mod..
Sam
Old Jan 6, 2005 | 01:46 PM
gdub's Avatar
gdub
I bought one from the traveling chinese tool sale for $100. It's foldable and is more than adequate for home use. I've used it to pull my small-block and trans. and to lift the body off my truck. No complaints.
Old Jan 9, 2005 | 02:38 PM
tdford's Avatar
tdford
Harbor Frieght Hoist
I just used Harbor Frieght's 2 ton folding hoist to lift a 1000 lb. 7.3 diesel out of my 4X4 F350 in the 1/2 ton position and never had any problems. It's foreign made but the workmanship is satisfactory. Had the same problem transfering to the engine stand and had to hang the engine on a chainfall hoist to get it mounted on the stand. I have the engine on the 2 ton Harbor Frieght stand. I also had to build a new engine mount bracket for the stand to fit the 7.3 but the stand itself is well made. I would have been afraid to mount that block on the 1000 lb. stand and roll it around on my shop floor but it looked like the 1000 pound stand would have allowed the transfer directly from the hoist.
Don
Old Jan 9, 2005 | 05:50 PM
sdetweil's Avatar
sdetweil
I have a 1250 lb stand too, the T shape, narrow front wheels, wide at the back... Used it for my son's Miata engine, same problem tho, getting between the hoist legs
I really like the 2000lb stand.. wish it was the folding version tho
Sam
Old Jan 11, 2005 | 09:06 PM
66fdtrucknut's Avatar
66fdtrucknut
Amen to the pep boy special. I've pulled a couple engines and a couple cabs and it works great and folds neatly in the corner.
Old Jan 12, 2005 | 06:29 PM
cantrma's Avatar
cantrma
sdetweil, Slide the mounting plate out of the base's collar. Bolt up the plate. Lift pretty high, pick up base and put it back together in the air. Put thick cardboard (unless you don't mind paint scrapes) over the legs of the hoist and let it down slowly and slide it off.
Old Jan 12, 2005 | 10:38 PM
sdetweil's Avatar
sdetweil
yeh, fight a 750lb 460 engine on a splay leg stand too.. fun..
Sam
Old Jan 13, 2005 | 12:00 AM
tdford's Avatar
tdford
I would think twice before attempting to slide any engine and stand off the top of the hoist legs onto the floor. Sliding off my hoist would create about a 4" drop and the casters aren't designed for a shock load plus there is the danger of tipping as the move was made. I did think about blocking the stand up, sliding the hoist out, and then jacking the stand down but with a 1000 lb. 7.3 bolted to it I elected to transfer the engine from the hoist to a 2 ton cable puller and then bolt it to the stand. Virtually 100% safe! It only took one evening to put a beam in the attic and place temporary legs under it.
