Rough Idling
Old Jan 2, 2005 | 08:01 PM
94 1/2 stroker's Avatar
94 1/2 stroker
Rough Idling
Hey fellas. Need help again!! Thursday I had a fuel bowl replaced. Ran the beast friday and saturday with no problem. Started the beast up this evening and while idling it started to cut out idle fine and cut out again and again till it finally died. Was a little hesatint to start back up but it did. Anywhere from a 1000rpms to 2000rpms it will cut out, even when I tried to drive it the same thhing happened. Talk about a bucking bronco!! Is this a fuel problem or is it a dreded cps sensor? Any ideas on where to start?? Thanks again in advance fellas!!
