Sponsored by: Real Truck
parallel Hell
Old Jan 2, 2005 | 06:51 PM
howarda's Avatar
howarda
parallel Hell
2000, f350, reg cab, 4x4 V10
When the truck is not moving and idling power steering is intermittent. For example when you are parallel parking and trying to crank the wheels around you might get halfway and then all boost is gone. If you take your foot off the brake and let the truck coast a few inches the boost returns. The pump is quiet but I'm assuming that it is bad.
I'm figuring that I'm not the first one to see this and would like to know what you found wrong.
Thanks!
Old Jan 2, 2005 | 08:18 PM
jetjock16's Avatar
jetjock16
you are not supposed to turn the wheels under powersteering, while you are not moving in any vehicle... let alone the heaviest truck on the road...... my tires are oversized and do the same thing, i cannot remember how well it did with stock tires, but regardless your supposed to be rolling to have the pump turn the tires or it will cause pre-mature failure, it is not meant to handle that abuse... just keep it at a slow crawl while you crank the wheel.
Old Jan 2, 2005 | 10:34 PM
3/4ER's Avatar
3/4ER
Power brake boost is provided by the power steering pump, apparently not enough pressure to go arround.
Thanks!
Old Jan 3, 2005 | 07:24 AM
bruuuuce's Avatar
bruuuuce
common problem among ford's. I don't notice it in my truck, but my buddy with oversized tires has a devil of a time parking his camper.
Old Jan 3, 2005 | 09:42 AM
chuck641's Avatar
chuck641
my brothers truck is the same way .. makes it interesting in tight parkin lots and parallel parking
Old Jan 3, 2005 | 01:52 PM
etcetera's Avatar
etcetera
Just a clarification, the Gas superduties have a vacuum brake booster. The diesels share the pump with the power steering.
Eric
Old Jan 3, 2005 | 02:13 PM
wvabeer's Avatar
wvabeer
I have had no problem with mine it turns easy whether stopped or moving
