Badger Pistons?
Old Jan 2, 2005 | 05:49 PM
timjk69's Avatar
timjk69
Badger Pistons?
Are Badger cast pistons decent quality? I found a decent deal on a set for my 1987 460.
Are most brand name pistons of good quality?
Tim
Old Jan 2, 2005 | 08:16 PM
Sunnude's Avatar
Sunnude
Badger pistons! They are just like the stock one's, very cheap great for very stock rebuilds. DO NOT push the limits of of this type of piston, it is A cast piece.
Old Jan 3, 2005 | 07:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you!~
See you on the boards.
Old Jan 3, 2005 | 08:05 PM
stevef100s's Avatar
stevef100s
I never use regular cast pistons. I usually use hypereutectic, which are a higher silicone content cast piston. Much tougher then regular cast, and are tighter fitting when cold then forged pistons. Forged pistons are the toughest, but can be expensive.
Old Jan 8, 2005 | 02:39 PM
TiggerF250's Avatar
TiggerF250
I have seen alot of cracked badger pistons in V8 Jeep Engines. I wouldn't personally use them I would go with a good set hupereutectic pistons. The last engine I tore down that had Badger pistons in it you could still see the cross hatching on the cylinder walls but 3 of 8 pistons were cracked.
Old Jan 8, 2005 | 03:42 PM
Brad Johnson's Avatar
Brad Johnson
Badgers!? BADGERS!!? WE DON'T NEED NO STINKING BADGERS!!!! And now, we're going to teach Poodles how to fly....
Welcome to the Forum!
Brad
FortyNiner
64
Apr 7, 2015 08:53 PM
madrockwyo
Mar 3, 2015 01:04 PM
jpbecker
Apr 3, 2014 11:33 AM
TMI
Aug 10, 2004 02:04 AM
