ping and chatter
Old Dec 24, 2002 | 11:47 AM
mjl351w's Avatar
mjl351w
ping and chatter
I have a rebilt 351W with 3500 miles. No matter where i set the timming the thing still pings on the freeway.I have new crane cam,lifters,push rods,MSD off road box,new auto zone vac.advance dist.,carter 625 cfm carb,edelbrock preformer intake,9mm wires,motorsport chain. NO HEAD WORK done yet.Do i need new heads?they are off a 94 351W F-350
Old Dec 24, 2002 | 06:42 PM
nickmobile67's Avatar
nickmobile67
ping and chatter
Sounds to me like you need better gas! What are you running? regular is surely not enough, try putting the highest octane you can get (less race fuel) on the next few fillups and see if it helps. 91 octane should do, Sunoco has 93 I think.
Old Dec 25, 2002 | 11:21 AM
mjl351w's Avatar
mjl351w
ping and chatter
[updated:LAST EDITED ON 25-Dec-02 AT 12:35 PM (EST)]Thanks nickmobile67 .But I did all that 87,91,93 SHEll,BP,Citgo every time same thing.Up hill,downhill don't matter. I mostly run 91 or 93 never ran any lower. IN time is at 14 BTDC, plugs are at .044 plugs are motor craft ASF 44C.I have no idea why it's doing it. thanks for trying.
Old Dec 25, 2002 | 01:09 PM
Ford_Six's Avatar
Ford_Six
ping and chatter
Possibly an overly lean mix, combined with no EGR.
Jared
Old Dec 25, 2002 | 07:24 PM
mjl351w's Avatar
mjl351w
ping and chatter
Thanks FORD SIX i'll try to richen it up let ya know .
Old Dec 26, 2002 | 10:21 AM
Franklin2's Avatar
Franklin2
ping and chatter
On some combinations of engines and distributors, I have found you can't run 14 BTDC. The stock vacuum advance has too much advance. But if you retard the timing, it will really kill your low end punch. I would disconnect the vacuum advance for an experiment to see if the problem went away. If it does, I would buy an adjustable vacuum advance (I think crane sells them) and dial in as much vacuum advance you can get, without it pinging.
Old Dec 26, 2002 | 01:09 PM
mjl351w's Avatar
mjl351w
ping and chatter
OK makes sense. I'll try that too. I thank you becuse this just sucks . thanks for all your help..
Old Dec 26, 2002 | 03:50 PM
steve83's Avatar
steve83
ping and chatter
