Noisy Valve Cover?
Old Jan 2, 2005 | 03:48 PM
project supercab's Avatar
project supercab
Noisy Valve Cover?
Hi I gotta 77 F-100 with an original inline 300 4 bbl holley and 1990 EFI head and rockers and EFI exhaust manifolds
the bottom end aint quiet by any means but I think my (EFI head) rockers are hitting the (STOCK 1977) valve cover and adding to the noise
anyone ever see or worse HEAR this??
P.S. the noise is RPM sensetive
same noise with 10W30 as with 20W50
new HVoil pump
Old Jan 2, 2005 | 11:42 PM
stractor's Avatar
stractor
You are probably right, I have a chrome stamped steel cover that was supposed to fit the 300 through 94 or so and it doesn't fit my 90 because of the size of the rockers. The rockers are too large. A change in the rockers was made in the late 80s from stamped steel to cast half shaft rockers and they are larger. You need an EFI cover it is taller.
stractor
Old Jan 3, 2005 | 06:20 AM
project supercab
Smile
thanks that was what I thought
I will fix today
Old Jan 3, 2005 | 11:59 AM
hermangarza's Avatar
hermangarza
i could i get an 87+ head and install it in my 81 carbed 300 without problems?
Old Jan 3, 2005 | 05:27 PM
project supercab
sure it runs great EFI has more compression
just watch valve cover clearance and use the EFI thermostat housing
Old Jan 3, 2005 | 06:08 PM
fordman300's Avatar
fordman300
and a tighter timing curve for less advance or you will have detonation
Old Jan 3, 2005 | 10:59 PM
hermangarza
i guess ill go look for a 87+ head
77_F150_4x4
32
Oct 1, 2016 04:12 PM
85lebaront2
Mar 12, 2014 05:51 PM
fordbozo
32
Feb 9, 2013 07:19 PM
ubereal2
Missouri Chapter
Jun 7, 2007 06:31 PM
restorit
May 29, 2002 11:32 PM
