Engine Blow By
Old Dec 24, 2002 | 07:07 PM
Chevy_Monza's Avatar
Chevy_Monza
Engine Blow By
Good day,
I've always had some problems with blow by on the Truck (82, F150, 351W, 2WD). Most of the time it just filled the PCV Filter in the breather. I'd empty and clean the filter every couple of weeks. I just changed the oil, and now its making a huge mess in the engine compartment. Its blowing up the DipStick, rolling down it and smokin' on the exhaust manifold.
Its also been blown off the dipstick, and most of that side of the compartment is slicked with oil. I've always used a brand name oil, however whatever was on sale. This time it was castrol GTX, and I did make sure to get the 10W30. I put 5.4L of oil in when i changed it. The manual called for 6L. I shouldn't have overfilled the crankcase.
I'm well aware that this problem is a sympton of wore rings. What I'm curious about is why it just started to blow out of the dipstick. I've cleaned the PCV Valve, and it didn't help. Aside from running a vacumn hose from the dipstick to the under the frame, what options do I have ?
gm_monzaAThotmail.com
Old Dec 24, 2002 | 08:50 PM
steve83's Avatar
steve83
Engine Blow By
The engine is wearing out, or you've got a blown head gasket. Do a compression test. The PCV system is only designed to handle a specific amount of crankcase air, and that much compression getting in there easily overwhelms it. Compression test.
Old Dec 24, 2002 | 11:24 PM
Chevy_Monza
Engine Blow By
I've done the compression test. They range from 95 to 105 psi. The valves chatter, and oil pressure readings of near zero are common. The engine needs a rebuild. When I changed the oil on sunday, I had no blow by from the dipstick. I've owned the truck for a year, and its never done that. I was looking for ideas, as to why I would change the oil, and the next day it would start blowing out the DipStick.
> Compression test.
Old Dec 24, 2002 | 11:32 PM
steve83's Avatar
steve83
Engine Blow By
A 351 only making 105psi? That means your highest effective compression ratio is only 8:1. I think they're supposed to be 9:1, but I'm not sure. Sounds like you need to face the fact that the engine is dead.
Old Dec 25, 2002 | 02:53 AM
Ford_Six's Avatar
Ford_Six
Engine Blow By
Castrol Oil is well known for it's cleaning ability, which is why I use it. It probably took out the last bit of carbon in the cylinder walls that was causing a seal. Either that, or by strange coincedence, a piston holed, or the pcv tube collapsed at the same time.
Jared
Old Dec 27, 2002 | 07:15 PM
Chevy_Monza
Engine Blow By
Well I just finished another compression test on the motor. Did it the proper way this time, pulled all the plugs at the same time. Got better results. Varied between 110 and 125 PSI. I'm going start looking at replacing all the PCV components.
>Jared
Old Dec 27, 2002 | 09:34 PM
steve83's Avatar
steve83
Engine Blow By
In addition to pulling all the plugs, you should have the throttle blocked full open during the whole test. If you get a low reading on one cylinder, you should put a couple of drops of engine oil into that cylinder, spin the engine a few times, and retest. If the oil makes a substantial difference, you'll know it's the rings & not the valves or head gasket.
Old Dec 27, 2002 | 10:30 PM
ssvashon5's Avatar
ssvashon5
Engine Blow By
