Rear diff tag numbers, please decode.
Old Jan 2, 2005 | 10:59 AM
kill_them_all's Avatar
kill_them_all
S8079 3L5588OD10
3.55 limited slip 8.8 rear end??
Thanks
Old Jan 2, 2005 | 04:34 PM
kspilkinton's Avatar
kspilkinton
Yep... second line tells all, 3L55 8 8 XXXX
Makes it pretty simple unless someone's done a gear swap on that diff. Then you count axle vs. drive shaft turns ratios.
-Kerry
Old Jan 3, 2005 | 01:20 PM
kill_them_all
So would this be considered a posi rear end or just a limited slip? Is this a standard feature or do only some trucks have it? Thanks.
Old Jan 3, 2005 | 01:27 PM
85e150's Avatar
85e150
Positraction, Equalock and a few other names are the mfg names for limited slip diffs. These are options on most cars and trucks.
Most work with spring loaded clutch paks, and are subject to wear to the point where they no longer provide "positive traction" or an "equal lock" on the tires.
Lockers are different...using spring loaded cams or locking devices that lock the spiders. These do "positively lock" the diff, and are clink clank and chirp jobs--thus not a usual option on most cars and light trucks.
If your diff will still spin both tires on dry pavement, you are in great shape. If only on wet pavement, you are in good shape, if only on wet ice, uuhhmm...
