Keyless Entry
Old Jan 2, 2005 | 03:49 AM
mtcfish's Avatar
mtcfish
Keyless Entry
Just Purchased a new F150 Supercab Friday XLT for my fishing charter/boat business that has no keypad entree. I see you can buy one online on the Ford f150online.com page... are they hard to install
Old Jan 2, 2005 | 05:35 AM
Birdhunter1's Avatar
Birdhunter1
From what I know of them they are a stick on deal. The use a frequency that is the same as your little key fob remote.
Old Jan 2, 2005 | 08:01 AM
mtcfish's Avatar
mtcfish
Look mom....no holes!
Old Jan 2, 2005 | 01:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
I just installed one on mine. Quite easy and you program like you would your remotes.
I have a small problem though. When i programmed my pad the remote stopped working. I'm tryin' to figure it out...
Anyway, I got mine BRAND-NEW for $66 off ebay and that included shipping to Hawaii.
Old Jan 2, 2005 | 03:52 PM
ChrisAdams's Avatar
ChrisAdams
Hi Monsta;
Sounds like you got the stick on unit, not the actual ford door handle with the keyless. Those tend to sell for about the same price on e-bay. Those you remove and replace your handle, hooking it to the factory harness.
You got the one that is actually a third 'fob' just in pad form with a combination. If I remember correctly, you have to program it like a new fob, doing all three 'fobs' at the same time.
I wish I could get one of those to work with a crimestopper keyless, but so far no luck.
Chris
Old Jan 2, 2005 | 04:06 PM
mtcfish's Avatar
mtcfish
The ford one is $165 and my dealer said he would match it installed...
Old Jan 2, 2005 | 04:50 PM
ChrisAdams's Avatar
ChrisAdams
50-80 on ebay. Installation is not hard. That's for either the OEM stick on keypad, or the built into the door handle keypad that uses your harness. Both only work if you have the ford keyless entry installed.
The stick on you could carry in your pocket, or install under the fender, etc.
The door handle you pull the panel off the door and swap the door handle. then you plug into the original harness and find the master code, hidden somewhere on your truck.
I don't have the ford brand keyless entry. I do want the touch pad entry, but I need one that will work with the crimestopper reciver.
Chris
Old Jan 2, 2005 | 09:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
Damn...I wanted the door handle but wasn't sure if it would plug right in.
No matter...my Ford parts guys are idiots. Surely they would've messed something up anyway...
And I didn't even think to look on ebay for the handle...
Old Jan 2, 2005 | 10:06 PM
pdroszell's Avatar
pdroszell
Dumb question, but whats the big deal with the keypad? I thought the key fob was probably more useful.
Old Jan 2, 2005 | 10:32 PM
Monsta's Avatar
Monsta
Sit. Stay.
I like being able to lock my keys in the truck and not have to carry them around. Plus, I don't lose them that way.
Old Jan 2, 2005 | 11:32 PM
ChrisAdams's Avatar
ChrisAdams
Smile
Handy for keys in left in the ignition, also great when you go to the beach. I almost never want to dip my keys in salt water...
Hi Monsta, I have bid on two of them lately, one door handle went for 50 on a by it now, the other bid 62. Of course, you know ebay, may never see another one.
Chris
7943063673
7942508864
Links had problem, but these are the numbers.
Not sure I wouldn't prefer the stick on, you can put it where you want, and it's easier.
