hi i'm new to the site and it's my first post
i have a 2001 and have a problem that just started. the engine cranks over for a longer period of time before it starts. it dosen't matter hot or cold,first start of the day or not,being pluged in or not. any help would be great thanks shawn
If it seems to be taking a while only after it sits I would look at your high press oil pump resorvoir and see that the oil did not drain out, it should be no more that 1" below the plug.
Welcome to the only family Ford Truck site, on the net. As you can see the members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
start by checking the basics. enine oil level and clean oil, good batt,starter,alt., must have good cranking speed. then check glow plugs and glow plug relay operation.
