Ebpv Does Not Work!
Old Jan 1, 2005 | 08:23 PM
18vtx00's Avatar
18vtx00
Ebpv Does Not Work!
does anyone know the criteria that the pcm needs to see to operate the EBPV?
oil temp? IAT? ECT?
12VDC 0r 5VDC?
possibly just a bad actuator but i would rather do the domplete diagnosis first.
looked in my mitchell on demand at work and could not locate a schematic or a flow chart for it though.
i disconected the valve rod and the butterfly moves freely, but it does not actuate no matter how cold it is.
i would also like to turn it into and exhaust brake once i get it working.
Old Jan 1, 2005 | 09:18 PM
18vtx00's Avatar
18vtx00
did i stump you guys????
Old Jan 1, 2005 | 09:53 PM
Fire Rooster's Avatar
Fire Rooster
Is the wiring harness in front of the pedistal plugged in?
Old Jan 1, 2005 | 09:56 PM
18vtx00's Avatar
18vtx00
yes, 2 wire molex
Old Jan 1, 2005 | 10:29 PM
Bluesbandit's Avatar
Bluesbandit
Simple solution, just turn it into an exahaust brake and don't worry about it. Or if it's stuck open, just don't worry about it.
Old Jan 1, 2005 | 10:43 PM
18vtx00's Avatar
18vtx00
isn't it needed for ploper warm up?
i live in MA
Old Jan 1, 2005 | 10:45 PM
18vtx00's Avatar
18vtx00
besides, you cannot use it as a brake unless you make it actually move first.
Old Jan 1, 2005 | 10:50 PM
barebackjake's Avatar
barebackjake
its controlled from air temp and oil temp, going through service manual finding more info
Old Jan 1, 2005 | 10:55 PM
18vtx00's Avatar
18vtx00
Smile
i realize that as stated, but i need the correct critrea to create a proper flow chart for my self.
thanks
Old Jan 1, 2005 | 10:59 PM
barebackjake
the ebp sensor is a variable capacitance sensor thats fed with 5 volts that produced a liniar analog voltage to indicate exaust back presure to control valve...
dang theres alot there for one stinkin valve
Old Jan 1, 2005 | 11:22 PM
gunfrk's Avatar
gunfrk
i live in MA
No, it isn't really needed for a proper warm up though as long as the actuator works you can still use it for warm up as well as a brake. When you exit the truck flip the switch so that when you remote start it will close (although the key still works fine.). You can get a ebpv sensor eliminator from DieselStop if you decide to just use it just for a brake so that a bad sensor doesn't defuel it like an overboost signal.
There are several lengthy posts on converting to a brake on this site and all are basically alike.
Old Jan 2, 2005 | 06:14 AM
18vtx00's Avatar
18vtx00
what i am getting is if the actuator does not move now, then adding a switch will not help if the actuator is bad. so i need to fix that before i go any further w/it.
thanks
Old Jan 2, 2005 | 07:28 AM
slc10844's Avatar
slc10844
oil temp? IAT? ECT?
12VDC 0r 5VDC?
Oil temp below 167*F, IAT below 45*F, 5vdc. According to the book, ECT controls fuel delivery.
Old Jan 2, 2005 | 07:34 AM
slc10844's Avatar
slc10844
Oh! Don't forget to check the exhaust back-pressure sensor on the front of the engine. An open or short will disable the exhaust back-pressure control.
Old Jan 2, 2005 | 08:12 AM
mr_fixit's Avatar
mr_fixit
I had the sensor go bad and it stored a code in the pcm . Until you clear the code the valve will not operate.
